The upload wp post tool allows you to set featured images in your posts
It requires a couple of things:
- Image in data64 format or src url inside the post
- Enable feature in post uploader tool
Assuming your post has images inside.
How to set featured images
Create new WP upload task
Check ‘with featured image’
As long as the post has an image you will see a green checkmark in the image column
If there are problems you can hover for hints
eg: Not enabling featured images
eg: No images in post
Choosing XML RPC or JSON API posting
SCM will automatically choose the correct posting method based on the URL and PASSWORD of your blog details.
Custom XML RPC
You can enter a custom renamed xmlrpc file eg.
JSON API
If you use an App Password ie the password has spaces in it, SCM will use the newer JSON API to upload posts.
eg App Password
ArC0 nuTV hDz9 zxpL CH0C GiLO
XML RPC Default
The default is to try the xml-rpc if you just enter the blog url with an admin username and password.
