SEO Content Machine Not Opening Normally
I am facing problem with SEO content machine, it is not opening regularly at all. I have tried updating it to latest versions several times. But still it is not opening at all. Whenever I click on it, it won’t open at all and doesn’t show up in task manager either.
I used codex app to fix SEO content machine, it took a long time and created vbs script to run the SEO content machine, but with every update, this VBS script it lost and I have to ask chatgpt app (codex) to fix it again and it will create VBS script everytime.
I can’t reinstall Windows and also want to take backup of SCM. Previously, I lost one of my major content project under SCM during these fixes.
I want to run it normal application but not sure how to do it, I have stopped using ChatGPT app too, because it kept running instances of its app in background which was consuming too much resources of Windows.
Can you guide me how to run it like normal app? If it can’t be run, I want to take backup of all products before re-installing Windows.
Make sure you remove all codex app fixes, clean slate.
There is a BETA here:
Download and run it,
Maybe this version fixes.
If nothing still appears, we might have to dig in windows err reporting, or the apps internal crashpad logs.
You said nothing appears, which means its crashing way at the start of the app launching so might require some digging.
If you do have codex still available, you can ask it to find :
a) Windows crash report for SCM
b) SCM crashpad logs in the install location
Those 2 will help us find the error quicker.
Sorry, codex is not working right now and I can’t make the SCM work again. Can you guide me how to get these details?
:hammer_and_wrench: How to retrieve Electron Crashpad files
Try this one first, if nothing here we can try windows error logs, but those are hard to get.
Thanks. I have those .dmp files and created zip file for all files. Kindly check and guide me how to fix this issue.
I looked into it and all crashes are from missing or unusable GPU.
You need to add
–disable-gpu
To shortcut before launching SCM.
