đź›  How to retrieve Electron Crashpad files
If the app has recently crashed, please follow the steps below to find and send the crash report files.
Windows
  1. Press Win + R
  2. Enter:
%APPDATA%\scm-next-plus\Crashpad\reports
Replace YourAppName with the name of the application.
  1. Open the folder and look for files ending in .dmp, .log, or .meta
  2. Select all files → Right‑click → Send to → Compressed (zipped) folder
  3. Email the ZIP file to us.
macOS
  1. Open Finder
  2. Click Go → Go to Folder…
  3. Paste:
~/Library/Application Support/YourAppName/Crashpad/completed
  1. Press Enter
  2. Select all files → Right‑click → Compress
  3. Send the resulting ZIP file to us.
Linux
Crashpad (or Breakpad) files are usually at:
~/.config/YourAppName/Crashpad/completed
  1. Open the folder
  2. ZIP all files
  3. Send to us
If You Can’t Find the Folder
  • Open the app and click settings > utility > find scm.db
  • Look inside that path for Crashpad or reports
  • ZIP and send those files.
Thank you! Your crash reports help us fix issues faster.
