Is there any way to add multiple keywords to create single article
Is there any way to add multiple keywords to create single article? and do the same thing for multiple articles.
I have checked the article on multiple blogging and bulk blogging for different categories and different websites. What I want to do is give it topic as main keyword and give it some more keywords to add to the same article and each topic I give it will have different keywords (5 to 20 keywords for each topic). Is it possible to do it with SCM?
Yes you can add sub keywords to an article, but that is used to provide extra content for the scraper only.
Are you planning to use the AI writer or the content scraper to create an article with multiple different keywords?
Depending on your answer, you will have different options.
I am want to create bulk articles in Article creator and want to use multiple keywords for same article. I am not using AI writer for now, only using Article writer for bulk article writing. For now, I am giving it title with custom prompt for AI models (Google Gemini, GroqAI, and SCM) to write detailed articles. Article length and quality is good but I want to add more keywords to make it more relevant to specific topic. I am writing prompts for these articles based on topics. I want to add keywords for each topics, but don’t know how to do it.
I want to ask if there is any way to add keywords for each topic like there is method for bulk mass blogging for different categories and websites at once.
Title (Given as Main keyword): Disadvantages of Democracy: 5 Flaws That Could Destroy Modern Governments
Sub Keywords: disadvantages of democracy, cuban missile crisis political cartoon
I will give article writer multiple topics with keywords for each topic to write article.
Sounds like you are using ai article creator and want extra keywords to put into your prompts.
I suggest you look into article variables.
How to use the keyword variable
If you want a tutorial with how to do this inside an ai prompt, let me know and I can write one up for you.
So you have keyword, then sub keyword variables that you add into prompts. That way each time you add a keyword you can also add extra sub keywords.
Thanks. I was able to use variable. I didn’t know that I have to enter the variable before to get it recognized.
Thanks a lot, it solved the problems which I was facing.
Manual for next time:
