How to create content for GSA SER
You can create content for import into GSA SER using the Page Pipeline Task.
SCM can create both GSA SER project data (you import) and html articles
You must do a manual import from text files.
Option 1: Create project + articles from scraped content
Under extracted pages, create > gsa ser
This will use content extracted from the SERPs to generate both GSA SER project file and html articles.
Option 2: Create project + articles from AI generation
You can also use AI to generate project and articles.
Click dropdown and select both GSA SER Article and Project data
Check the article count settings.
For GSA SER articles you can create as many as you want.
For GSA SER project data, you only need 1.
How to import into GSA SER
Project data
Inside GSA SER > Tools
Auto Fill > Use SEO Content Machine >Import
Ignore ‘Use Api’ as it does not work!
Select file from project data folder
Confirm fields
This will import and fill the project data.
Article Manager
You can also import extra articles.
Article Manager > Add
Import from folder
Point to output article folder
Titles from tags
Articles added
I am heavily dependent on tiered link building and recently switched back again to SCM to generate content for GSA SER and noticed the UI is 100% changed and slick! (awesome) But now I am missing how to generate content for GSA SER? How to do that also other tools.
Edited: Found it inside ‘Page Pipeline’
Hope it helps with others as well.
Cheers for great piece of tool
Gsa ser templates are now in 2 places.
For ai content, you select both gsa templates. One for articles one for project data.
For scraped content generator ie classic scm content generation, it’s the same as you remember it.
Just select gsa from template dropdown.
Content generator is now named page pipeline.
More changes in coming, especially as I am spending time polishing up the ui and working on making a unified workflow with less clicks.
A post was split to a new topic: Videos not inserting when set to 0-1
