Videos not inserting when set to 0-1
Hello Tim,
I am generating content for my t1 and I want to add random videos from my own channel so I provide the channel username and set 0 to 1 video and all articles come up with 0 videos. Is that a bug? Seems when 0 select SCM not working properly and it’s not generating random. Can you double check?
Fixed in next update
You can just use @handle, or channel ID
Verification
Hello. Thanks for the update, will try. I am not sure if it’s okay to ask these kinds of questions here or if you can guide me where I should ask. I wanted to create articles this time for MONEY ROBOT (very bad tool when compared with GSA SER, but still use it as some of their domains are worth having, so yeah, don’t judge me on this lol). Anyway, I asked SUPER SPIN file to create and enter 50 articles, but I got 10 files. So I am unable to import into Money Robot since I will have to copy paste or import just a single file. Why does SCM provide 10 files with spin instead of one large super spintax file?
Did you have 10 keywords?
Damnt yes. Is that the reason. Got it then yeah i had. Anway is there anyway to combine all these files to one spintax file ?
Preview
Then you can try this new option in the next update
But articles have to match exactly in length and addins or else you might extra images or videos.
Try it see if it is usable.
In general, you cant combine already spun files together.
