Also, is there a possibility to add images to articles from my folder? If not, that would be very useful feature.
This is a very important feature. Currently after generating the text it takes a long time to manually generate base64 images for all posts. It would be great if in the “Preview article” section there was an option to manually choose our own images for which to generate base64 and include them in the article.
If we can use them for the option “existing articles” as “inserts > image” and the inserts are base64 (suitable for featured images). It will do a perfect job.
I would love to see a video explaining how to do long article with 2 or 3 images from AI in bulk, what´s the maximum articles i can create with my openai key? i don´t know if is possible to save in csv all articles to import after to wordpress.
Yes, I will add this to the next update.
Images will be read from your hard drive and inserted as base64 images
Use AI outline
Just enable Insert Images
CSV not yet supported with AI articles
It is in progress…
Another alternative is to create your content on your hard drive then use ‘Create WP XML’ to generate an a file that you can use Post > Import
3 posts were split to a new topic: Unable to write long articles
