It is possible to create a long form article in the Article creator using an AI generated outline.
The advantages
- Long articles that normally exceed 4000 words
- Articles with subheadings and sections that don’t repeat and are unique (vs doing it yourself)
- Simple process, just select the AI template.
How to write long form using the AI outline template
Inside the Article creator:
Load prompt
Select Article html - AI outline
Click load prompt
Verify prompt was loaded correctly
There will be a special tag inserted
Set article count as needed
Insert article keyword
Hit run
Sample
Following article was 7,247 words long
what is green tea.zip (14.0 KB)
