Hi. Sometimes it complains that there is no title. There is no way for me to delete it, but to go directly at the directory. Its hard to look for the actual article to fix or delete.
I know, but it would be easier if it can be deleted within the APP. Or a button that will ignore all problematic articles, so they dont get posted.
I can add a ‘open’ file link to that tooltip while I figure out a more permanent solution.
Ideally it would scan the entire dir of files and reports errors.
I am revisiting the post import table,
- Add paging for unlimited post preview
- Add remove button to get rid of unwanted posts
