Use an AI outline to write a long article
The problem:
You can try feed outline into n article prompt.
eg
However, the output is limited to around 600 words.
If you use multiple sub heading macros.,
eg:
It can start generating the same duplicate headings in the article.
Solution:
Use AI generated outline to create long articles
this will create similar and repeated subheading.
see screenshot. all the headings are exactly the same just phrased differently.
Answered here at the end
This method here has some limitations.
I am prototyping a different way of using AI written outlines to create large articles.
i tried this, however it is still repeating its heading.
Did you enable scraped content?
How do i enable scraped content?
is it like that?
You are using a very specific long tail keyword.
I ran a test
Output
Hamsters: How Long Can They Live Without Food and Water?
How long can hamsters live without food and water in case of illness or dehydration?
How long can a hamster live without food and water? Understanding the importance of proper nutrition for your pet.
Neglecting to provide food and water for your hamster can have detrimental consequences.
How Long Can a Hamster Live Without Food and Water: Encouraging Litter Box Usage
Should I hold my hamster everyday?
Do hamsters like being alone?
Will a hamster come back if it escapes?
Can hamsters go 2 days without water?
With %related_keywords% there is some repeats however %scraped_sentences% seems to work out better.
Try it with %scraped_sentences% for slightly better results
I also tried Google %paa_question% and although it is unique, the results are a bit to broad.
I think the real solution is that we let the AI write an outline and use that outline to create the article, works even for long tail keywords where there isn’t much in terms of related content.
I guess I will have to wait till you find a way to do this. I tried using scraped sentences, but the sub headings still seems to be repeating.
Dev update log:
Lots of testing behind the scenes getting AI outlines to generate and parse correctly.
It shows some promise.
Everything here is still up for change.
To keep UI changes minimal, most likely there will be an tag to turn on AI outlines.
Everything between the tags will be used as the prompts to create each subsection of content from an AI outline.
The way AI outlines work is:
  1. SCM sends a prompt to generate an outline using h2 and h3 tags using your keyword.
  2. The resulting AI generated outline is then parsed line by line to create a long article prompt with the correct <h2> and <h3> structure.
  3. This new outline prompt is sent to the AI model to be filled out.
To give an example of the steps.
Keyword is “Where to Find the Best Street Food in Tokyo”
Prompt sent to create initial AI outline
Disregard previous instructions.
Create an article outline without an introduction about Where to Find the Best Street Food in Tokyo in language English.
Each section starts with a <h2> tag and each subsection starts with a <h3> tag.
Each line must start with a h2 or h3 tag.
Dont start with introduction.
Resulting AI prompt returned
<h2>Best Street Food in Tokyo</h2>
<h3>Tsukiji Outer Market</h3>
[write a short answer about Tsukiji Outer Market Where to Find the Best Street Food in Tokyo wrap your response in <p> tags {and use <em> and <strong> tags on keywords|||}.
{Use bullet points or numbered list||||}]
<h3>Takeshita Street in Harajuku</h3>
[write a short answer about Takeshita Street in Harajuku Where to Find the Best Street Food in Tokyo wrap your response in <p> tags {and use <em> and <strong> tags on keywords|||}.
<h3>Ameya-Yokocho Market in Ueno</h3>
[write a short answer about Ameya-Yokocho Market in Ueno Where to Find the Best Street Food in Tokyo wrap your response in <p> tags {and use <em> and <strong> tags on keywords|||}.
<h3>Shibuya Food Alley</h3>
[write a short answer about Shibuya Food Alley Where to Find the Best Street Food in Tokyo wrap your response in <p> tags {and use <em> and <strong> tags on keywords|||}.
<h3>Yanaka Ginza in Yanaka</h3>
[write a short answer about Yanaka Ginza in Yanaka Where to Find the Best Street Food in Tokyo wrap your response in <p> tags {and use <em> and <strong> tags on keywords|||}.
This prompt is in SCM AI writer compatible code.
Notice the use of [ ] to mark prompts and the inclusion of {|} spintax to randomize the prompts.
The final output is 391 words long.
But can be made much longer as the current prompt per section is “write a short answer”
<outline>
[write a short answer about %outline_heading% %keyword% wrap your response in <p> tags {and use <em> and <strong> tags on keywords|||}.
</outline>
Notice the use of %outline_heading% in the prompt.
This is used to refer to each <h3> section given by the initial AI outline.
Currently more testing is being undertaken to optimize the prompts.
The biggest issue is that the AI doesn’t always neatly return a properly formatted article outline!
Using the method also means we can add AI generated images that are relevant to the outline heading too!
Here is the actual created article below for reference:
Choosing the Right Vehicle
Determining the type of vehicle needed
When determining the type of vehicle needed for your first road trip through Australia, it's important to consider the terrain you'll be traveling on, the number of people in your group, and the amount of luggage you'll be bringing. If you plan on exploring remote areas or rough terrain, a 4WD vehicle may be necessary. For larger groups or families, a spacious SUV or van might be more suitable. Ultimately, choosing the right vehicle will ensure a comfortable and safe journey throughout your Australian adventure.
Renting vs. buying a vehicle
Renting a vehicle may be a better option for your first road trip through Australia. This allows you to have a reliable mode of transportation without the commitment of purchasing a vehicle. Additionally, renting can often be more cost-effective for short trips or occasional use. However, if you plan on doing multiple road trips or staying in Australia for an extended period of time, buying a vehicle might be a better investment in the long run.
Essential features to look for in a road trip vehicle
Essential features to look for in a road trip vehicle Planning Your First Road Trip through Australia include:
  • Comfort: Ample legroom, air conditioning, and comfortable seating.
  • Reliability: A trustworthy engine and well-maintained vehicle.
  • Storage: Sufficient space for luggage, camping equipment, and other essentials.
  • Efficiency: Good fuel economy for long drives and remote areas.
  • Safety: Airbags, anti-lock brakes, and stability control for a secure journey.
  • Entertainment: Audio system, USB ports, and smartphone connectivity for a pleasant ride.
Mapping Out Your Route
Researching popular destinations in Australia
When researching popular destinations in Australia for your first road trip, it's important to consider a variety of factors. From iconic landmarks like the Great Barrier Reef and Uluru to vibrant cities such as Sydney and Melbourne, there are endless possibilities for exploration. Planning your itinerary carefully and researching the best routes and accommodations can help ensure a smooth and memorable journey. Be sure to also research local customs and regulations, as well as any necessary permits or passes for national parks. With proper planning and research, your first road trip through Australia is sure to be an unforgettable adventure.
Creating a flexible itinerary
Creating a flexible itinerary for your first road trip through Australia is essential for a successful and stress-free journey. By allowing for spontaneous stops, changes in weather, and unexpected discoveries along the way, you can truly immerse yourself in the beauty and culture of this diverse country. Be sure to include must-see destinations and activities on your list, but also leave room for detours and off-the-beaten-path adventures. This approach will not only make for a more enjoyable trip but also create lasting memories that you'll cherish for years to come.
Considering driving distances and travel time
When planning your first road trip through Australia, it is important to consider driving distances and travel time. Australia is a vast country with long stretches of roads between cities and attractions. Be sure to plan your route carefully, breaking up long drives with rest stops and overnight stays. It's also a good idea to familiarize yourself with road rules and regulations in Australia, as well as have a reliable GPS or map with you at all times. By taking these factors into account, you can ensure a smooth and enjoyable road trip through this beautiful continent.
Managing Your Budget
Calculating fuel and accommodation costs
Calculating fuel and accommodation costs for your first road trip through Australia is essential in order to stay within your budget. Consider the distances you will be traveling, the fuel efficiency of your vehicle, and the prices of gas in the areas you will be visiting. Additionally, research potential accommodations such as campsites, hostels, or hotels, and factor in the nightly rates to determine your overall expenses. By carefully planning and budgeting for these costs, you can ensure a smooth and enjoyable journey through the vast Australian landscape.
Setting aside funds for unexpected expenses
Setting aside funds for unexpected expenses is crucial when planning your first road trip through Australia. From car troubles to sudden changes in accommodation, having a financial buffer can provide peace of mind and ensure you can handle any surprises that come your way. It's always better to be prepared than to be caught off guard while traveling in a foreign country. So, make sure to budget for these unexpected costs when planning your road trip Down Under.
Utilizing budgeting apps or tools for tracking expenses
Utilizing budgeting apps or tools for tracking expenses can be incredibly helpful when planning your first road trip through Australia. By keeping track of your spending, you can better manage your funds and ensure you stick to your budget throughout your journey. These tools can help you identify where you are overspending, allowing you to make adjustments and stay on track financially.
Packing Essentials
Clothing and footwear for various climates
Clothing and footwear are essential considerations when planning your first road trip through Australia, as the country has a diverse range of climates. From the hot and dry Outback to the cooler temperatures in the southern regions, it is important to pack layers and versatile pieces that can easily be mixed and matched. In warmer areas, lightweight and breathable fabrics are key, while in cooler regions, warmer layers and waterproof gear may be necessary. Additionally, comfortable and durable footwear is important for exploring different terrains, whether it be sandy beaches or rugged hiking trails. Be sure to pack a variety of clothing and footwear options to suit the varying climates you may encounter during your road trip.
Camping gear or accommodation supplies
Camping gear or accommodation supplies are essential for any road trip through Australia. Whether you choose to camp in the outback or stay in budget accommodations, having the right gear and supplies can make your trip more comfortable and enjoyable. Be sure to pack essentials like a tent, sleeping bag, cooking utensils, and mosquito repellent. Additionally, consider investing in a reliable GPS or map to navigate the vast Australian landscape. Happy travels!
Emergency supplies and first aid kits
When planning your first road trip through Australia, it is essential to pack emergency supplies and a first aid kit. Australia's vast and diverse landscape can present unexpected challenges, such as extreme weather conditions, wildlife encounters, or remote areas with limited access to medical facilities. Having a well-stocked first aid kit with essentials like bandages, antiseptic wipes, pain relievers, and a thermometer can help you be prepared for any minor injuries or illnesses that may arise. Additionally, packing emergency supplies like extra food, water, a flashlight, and a map can ensure you are ready for unforeseen circumstances. It is always better to be over-prepared than under-prepared when traveling in Australia.
Staying Safe on the Road
Understanding Australian road rules and regulations
Understanding Australian road rules and regulations is essential when planning your first road trip through Australia. It is important to familiarize yourself with topics such as driving on the left-hand side of the road, speed limits, and signage. Additionally, requirements such as wearing seatbelts and not using a mobile phone while driving should be adhered to. By following these rules and regulations, you can ensure a safe and enjoyable road trip experience in Australia.
Checking for vehicle insurance and roadside assistance
When planning your first road trip through Australia, it is crucial to check for vehicle insurance and roadside assistance. This will ensure that you are protected in case of any unforeseen circumstances while driving in a foreign country. It's always better to be safe than sorry, especially when embarking on a long journey.
Sharing your itinerary with friends or family for safety precautions
Sharing your itinerary with friends or family when planning your first road trip through Australia is a crucial safety precaution. Not only does it allow your loved ones to know where you are at all times, but it also provides them with the necessary information to help in case of an emergency. By sharing your itinerary, you can ensure that someone is aware of your planned route, accommodations, and activities, making your trip safer and giving you peace of mind.
Is it already implemented in scm? Also, all the written content will be up to date with scraped content?
Its in internal testing right now.
Above was just to highlight proposed changes.
If you can give me a keyword, I can run it on my end to make sure output is good.
:star2: Good news! Feature is ready for public testing!
Please find the newly added AI templates when you update.
Just hit run, no other tweaking required to get it running!
With a long outline I got big long articles
cool, the 1st template looks good. I tried the 2nd template and it gives some weird results.
keyword is beginner hamster training. The heading is quite off from the keyword
It uses scraped subheadings so it can be random.
I think if you put content filter on it you could get better subheadings.
However it’s more a proof of concept.
I think 1st template is the way to go.
sure. I will go with first template. Do you think I can change the prompt slightly like indicating 1500 words so that it does not make super long content. Nowadays no one reads such long article anymore. haha
Not really as ai models don’t keep to word length requests.
But you can change prompt in outline to:
Write a short answer…
As for how big the outline is, totally random and up to the feeling of the ai model at that time of day when you ask it :slight_smile:
Hi Sir,
what is this macro for? [outline:]
Left in by mistake.
It won’t do anything.
