To make it easier to find AI templates, I have added tagging and filtering to the AI prompt window.
Load prompt window now looks like this.
Templates are tagged, eg longform
You can filter templates by tag, by clicking on the types filter.
Click ‘longform’
Just shows templates with longform tag
You can add your own tags using csv
This should make it easier to categorise and find templates.
Finally a new template has been added that builds an outline from the top 5 ranking articles from Google and uses it to write an article.
We do this by adding extra %scraped_article% macros
There is warning message if you select this template but not a source for articles.
So choose add search or local articles and this error message disappears.
