Subfolders bug
updated to 26.10.1834
I have noticed a new bug. Never seen it before. While generating articles via “Extracted content”, there is a bug that creates unnecessary subfolders. 2 of 7 tasks ended up creating such subfolders:
Each subfolder contains a proper txt file, but the names are just “2024” or “2026”. Could you take a look, please? Is there a chance it may have something to do with my filename format? We have been using this format for a while and have never seen this type of bug
Known issue.
Should be fixed in next update.
It’s the title macro, if it has /, it creates extra folder.
Hi Tim, the subfolder issue seems to be fixed now. I wanted to report just a tiny UX issue that appeared in the latest update. Earlier, when you created or duplicated a task within Page Pipeline, it used to remember the tab you used under Page Source, but now it always displays the “ai pages” tab by default even if you don’t use it. Could you please make it as it was earlier?
Sound alike bug.
Will fix it in next update.
