Tim
1
When running older versions of SCM you can get a problem with request: certificate has expired error message.
Tim
2
Solution
Create a .bat file inside the SCM install folder with.
set NODE_TLS_REJECT_UNAUTHORIZED=0
start ./“SEO Content Machine.exe”
Set the ENV variable NODE_TLS_REJECT_UNAUTHORIZED to disable the certificate check.
The newest versions of SCM do not have this issue.
