Post to WordPress directly from SEO Workspaces
Currently you can only publish to WP using the AI to do it for you.
Or you can do it yourself by exporting article and calling WP publish tools yourself,
Although AI pub is nice, sometimes its faster and more convenient to do it yourself, without the risk of AI burning down your site with wrong calls.
A deterministic button > AI assisted calls for basic ops.
To that end I am adding buttons to
a) Bulk publish
b) Single post publish
How to bulk publish post / pages
When you select multiple posts that have a draft on file, you get the publish button.
No draft, just create.
Draft, publish.
The create button is demoted but still there.
The publish button opens a new window.
You can assign a blog and choose to post as page/post or publish/draft
You can also assign articles to separate blogs…
Which expands the window to give you per article control now.
How to post a single article
Inside the article editor is a publish button
Click on it to show a publish window
Once published it will give you a link to the live post.
Track published pages
There is basic tracking of when you publish pages and warns you that update will be called.
Same if you are writing an need to update live post.
Now you have 2 paths, AI to post or at anytime post it yourself.
More updates to this.
Now the publish feature is available from the site plan side as well.
Select any node in site plan to create or publish
Selecting nodes will allow create and publish
You can shift click or click and drag to select.
Shift click works on the tree as well!
NB: The old select page to add to selection step is removed. The table and site plan selection is now separate. Greatly simplify the ux.
SEO Workspace bulk tools UI simplified
When you select multiple pages you get 3 actions.
The first 2 important create/publish always visible.
Extra actions inside the hamburger
  • Set status
  • Add to site plan
  • Copy
  • Delete
Other
  • Hub pages now called ‘hub’ and not ‘main’
  • Alot of missing buttons in both table and site plan have been added
