OPEN API max_tokens max_completion_tokens
Please update it so that the max_tokens value can be adjusted!
Max tokens are not set in api, so it will default to largest size.
Do you want to set a smaller Max token size?
For example, I would like to call the max_tokens parameter when making a request to OpenAI as shown below.
The reason is that I want to generate longer articles.
import openai
response = openai.ChatCompletion.create(
    model="gpt-4o-mini",
    messages=[
        {"role": "system", "content": "You are a helpful assistant."},
        {"role": "user", "content": "Write a detailed article about dog story."}
    max_tokens=1200
For Max tokens you should leave it blank for longest possible articles.
Max tokens include the prompt length. So if your prompt is long it creates shorter articles.
I can add it though on next update.
Thank you so much for providing the update.
Have a great day today!
Max tokens!
Slight change because max tokens is now deprecated in favor of a new param
The update hasn’t been implemented yet, right?
I don’t see it in my settings yet.
It’s ready now.
Try download now.
