Lots of performance improvements to SCM UI to handle large databases with lots of tasks.
These tweaks are for large SCM databases with 700 tasks+.
This is where you will see the most improvements.
Less UI lag
Deleting and starting tasks no longer cause large micro stutters in the UI.
Better task display
All SCM tasks now use paging to display tasks.
If you have a really laggy VPS you can set to 10 tasks per page.
It will make the rendering much faster.
Compress your databases
As you add more tasks, the database will grow in size and accumulate trash.
You should consider running a compact operation.
