Is there a way to just scrape article titles?
Sometimes I need 2000 to 3000 relevant titles to my niche for article creation.
If you just run the article creator and set result limit to 300. You will get 300 titles per search.
Then after task is run, you can go to content cache to find your titles.
Add more keywords to get more titles
You could also use the webcrawler and have it find permalinks on a site and use those as titles?
