The problem
I can’t insert macro at the beginning or end of the article -
Simple solution
Can you add a function that allows you to add to the beginning of each text selected macro, so that you can add, for example, the appropriate title, or some insertion? The same at the end of a given article?
Attach screenshot of your settings.
Confirmed as bug.
Fixed in next update, please update and check it works.
You are using the the ‘existing articles’ content insert right?
Fixes was put for scraped content only.
I have rolled out fixes for existing articles generator as well.
