Tim
1
Current article creator directions insert requires destination and hardcoded origin.
2. Simple solution
Allow random origins within xx km radius from destination
Tim
2
POC: Able to generate random direction embeds now.
Same destination but origin is random
Tim
3
New UI WIP
For Google multi directions.
Rather than replace Google directions, I might add a new tab so that the old tab will function as it use to.
Ryan
4
Where in SCM we can generate the directions map? didn’t know this can be done in SCM.
Tim
5
Article creator, Inserts Google direction.
Tim
6
You can select a destination directly on the Google map window now.
Added travel options etc.
Embeds are cached, and used sequentially one per article.
