You can insert AI generated images into any existing content no your hard drive using the Article Creator.
The steps are:
- Have a set of articles ready to go on your hard drive
- Create article creator task
- Use ‘existing articles’ selector
- Enable Image insert
- Enable AI image generation
Create a new task
Enter keyword the AI image generator will use
Select existing articles
Under generator, enable Existing articles
Turn off all other options
Select location of your articles
Verify article count
We are only inserting images and not scraped content
Set search urls to 0
Enable image insert
Enable Image
Select location of images
eg. 1 image in random location
Turn off all image options except AI images
Select AI image service
Image service API keys can be entered in settings > api logins
Enter number of images to generate
Images are shared across all articles in the folder
If you want a unique image for each article, you need to generate as many images as there are articles
Eg: 5 articles, so 5 images
Run task
Verify AI images are being generated
Preview completed article
Verify AI images
