How to use the AI Writer to rewrite / paraphrase content
It is possible to use AI models to rewrite/paraphrase content inside the App.
Eg: Use openai very clever gpt4 to rewrite content sentence by sentence. ie using it as a paraphraser to make content unique.
Update: the AI rewriter now sends the whole article in 1 prompt, not sentence by sentence.
How to select the AI rewriter
Look out for the Rewriter module inside tasks
Select ‘AI rewriter’ to use AI to rewrite content
It sits under the ‘AI rewrite’ group
Settings are displayed along with a usage warning
Hover the warning icon next to ‘AI model’ to read it
You can request multiple rewrites as well.
Set rewrite count higher than 1
The AI model is picked inside each task
Use the ‘AI model’ field under ‘Rewriter’
There is no Default AI dropdown in API logins any more
To change the prompt used to request the rewriting
Click ‘Edit prompts’ next to ‘AI model’
‘Article rewrite prompt’ is used when the whole article goes in 1 prompt
This is how RSS & Sitemaps, Rewrite & Translate, Search & News and Page Pipeline ‘Existing pages’ work
‘Paragraph rewrite prompt’ is only used by Page Pipeline ‘Extracted content’, which still sends chunks of about 250 words
The prompts save app wide, not per task
Check the rewrite
Hit ‘Run’
04-run
The log shows 1 prompt with the whole article inside
Open the preview to read the rewritten article
AI rewriter FAQ
What is an AI rewriter?
It sends your text to an AI model with a prompt that asks for a new version. The meaning stays, the wording changes.
How do I rewrite content with AI?
Pick ‘AI rewriter’ in the ‘Rewriter’ field of a task and choose an ‘AI model’. Then hit ‘Run’.
Does the AI rewriter rewrite paragraph by paragraph?
No, most tasks send the whole article in 1 prompt. Only Page Pipeline ‘Extracted content’ still sends chunks of about 250 words.
Can I rewrite a folder of text files?
Yes, use Rewrite & Translate. Point ‘Article location’ at a folder of .txt files and it writes the rewrites to ‘Save location’.
Can I change the AI rewrite prompt?
Yes, click ‘Edit prompts’ next to ‘AI model’. The change applies to every task.
Thanks for this [rewrite / paraphrase content] topic.
I want Ai to rewrite this
"Title: 4 in 1 Soil Acidity Alkalinity Sunlight Moisture Temperature Ph Meter
Descriptions
It combines several features to make your plants happier. By using the meter, you will know what your plant needs.
Your plant will be healthier and grow.
This 4-in-1 design (moisturizing/pH/glossy test/temperature) provides you with a comprehensive idea of the garden and lawn soil conditions. With a quick check, you can tell if you need to adjust the plant food/water, and whether your plant has enough sunlight and good temperature.
It uses the battery, you can use it after installing the battery.
Plug and play makes gardening easier than ever.
Compact and portable, indoor/outdoor use. Whether you are a gardener or a large farm personel, as long as you are interested in plants, this is an excellent tool for you."
Can you demo this step by step.?
I do not know where Ai rewriter can be found among the categories. I have checked it under Ai content but couldn’t find it there. Where is it hidden?
Where can I paste the above article to be rewritten in SCM window?
With already written content you have 2 options:
Preview article
Paste into textbox
Edit > Rewrite
Select AI writer
Re write
Spun content
If the output needs tweaking, you can edit the prompt.
Bulk re-write
You can also bulk re write content on your hard drive
