How to use AI to generate spintax text
With the AI being a valid rewriter option, its possible now to have the AI create spintax text with {|} symbols.
How to tell the AI to use spintax
Under API settings, change the rewrite prompt.
To :
rewrite the sentence using spintax symbols { | }
Now when you chose AI to do the rewriting it will create spintax text.
Example
Using GroqAI:
{{Green|Green tea} has been cherished for {centuries|ages} not only for its {refreshing|invigorating} taste but also for its {numerous|multiple} health {benefits|advantages}. Originating from {China|Asia}, this type of {tea|beverage} is celebrated {worldwide|globally} and is often associated with {wellness|health} and {vitality|energy}. Its {unique|distinct} processing method preserves the {natural|organic} antioxidants and {nutrients|ingredients}, making it a popular choice among {tea|beverage} enthusiasts and {health-conscious|fitness-oriented} individuals alike.|<p>Green tea has been cherished for centuries not only for its refreshing taste but also for its numerous health benefits. Originating from China, this type of tea is celebrated worldwide and is often associated with wellness and vitality. Its unique processing method preserves the natural antioxidants and nutrients, making it a popular choice among tea enthusiasts and health-conscious individuals alike.</p>}
It is able to generate usable spintax content.
Notice however that in example above, the non re-written text also appears (this is original text).
To remove original text choose remove in the rewrite options.
Do you still need to use a word rewriter?
If you change the default rewrite, you should no longer need to use another word rewriter.
Make sure it is none.
