If you used the super spun feature in the article creator, you can undo the operation.
The super spun is this.
Inside the export section.
Now you can undo this operation and break the 1 file into many files again.
Open the super spun article in the article preview window.
Find File > undo super spun
Files are exported in same directory of original article
Look for unspun in file name
