How to spin/re-write non English content
SCM has first class support for re-writing English content. This means coming with a free English spinner (Soft Spin) and support for 3rd party spinners like WordAi or even rewriting using ChatGPT via the AI Writer.
For other non English content you have a few options from easy to hard.
Example. Rewriting Korean text.
Option 1: AI Writer
Its possible to use the AI writer to re-write non English content.
The first step is to customize the AI rewrite prompt.
  1. API Logins
  2. SCM AI Writer
  3. Customize AI Writer prompt.
eg: rewrite in Korean the following
Prompts can also be written in your target language.
eg: Using google to write a korean prompt and using it in SCM.
To use the AI Writer, enable Article re-writer and then select AI Writer.
eg: Article Creator
eg: Preview Article Tool
Option 2: Find a Spinner that supports your language
XSpinner supports multiple different languages.
There are some native spinners for French etc
The full list of spinners supported by SCM are listed below:
  • Soft Spin English
  • Soft Spin Vietnamese
  • Chimp Rewriter
  • Content-spinning.fr
  • Dispara Tus Ingresos
  • ESpinner
  • Reescritor
  • SpinnerChief Paraphraser
  • Spin Rewriter
  • Sistema Br
  • Word Ai
  • X-Spinner
  • The Best Spinner
Option 3: Build your own custom synonym database
You can load a plain text dictionary file that contains a list of words and their re-writes.
The file must use the following syntax.
word|syn1|syn2
word 2|syn1|syn2
The dictionary location is set via API Logins
It will appear as ’ Custom Thesaurus’ in the spinner list.
