Hi,
How can i set article tone for specific author? if i want tone of some reputed online tone, where to set it? in Prompt?
Hi,
Edit an existing template and add the instruction for tone directly in the prompt. eg:
Open editor
Duplicate or Create new template
Edit prompt
Prompts are inside [ ] brackets. Anything outside of [ ] is not sent to the AI model.
Edit all [ ] prompts if required.
Save
Select
Verify
If you want to make a global edit to ALL prompts you can change the default prompt.
Every request sent to the AI model includes the default prompt at the beginning.
So you can include your tone requirement here to.
Now all your requests to the AI model will be in the tone of cookie monster.
Verify
i tried it but it’s not following tone of author. Open ai don’t have field for default prompt. i am using open ai
Send me screenshot of where you put tone.
