How to scrape more content in the Article creator using sub keywords
How keywords are used by the Article Creator
Default keyword list usage, 1 primary keyword per set of articles.
eg: 3 keywords, all unrelated.
Each keyword is used to scrape content and when its done, the content is flushed from memory and the next keyword is used.
After task is run, you get content for 3 different keywords.
Problem: What if you need more content than 1 keyword can provide?
Eg: Create an article with 999 paragraphs of content.
Just scraping the top 100 results will only give you so much content.
eg: 139 unique paragraphs.
There are 2 methods to scrape more data.
Solution 1 - Increase URL result limit to 300
Grab the result limit slider and raise to max.
Solution 2 - Use sub keywords
We can add extra keywords to our initial search.
eg: Use pipe |, to add a list of keywords.
what is green tea|green tea origins|green tea history
The primary keyword = what is green tea
Sub keyword 1 = green tea origins
Sub keyword 2 = green tea history
Unlike putting each keyword on its own line, sub keywords add extra content to the primary content.
When running…
Primary keyword
Sub keyword 1
Sub keyword 2
Total content found
All 3 keywords worth of content is available to the article creator.
Which means x3 the number of content if you just used 1 keyword.
If I use ServerAPI, will I only be charged for 1 search? How would that work? Or does it only work with Bing?
Each sub keyword will consume an extra search. So if you are using any API it will be a new search.
