When you choose AI to do your text re-writing you can also apply a word rewriter service to it.
Choose AI rewriter.
At the bottom is the word rewrite service.
The effect is to take AI rewrites and parse them to a word rewriter.
Tips
- The more recent and larger the AI model, the less problems it will have with creating spintax.
- Change to a different AI model if it is removing HTML from your article incorrectly. eg: GroqAI likes to remove HTML while OpenAI will work correctly with HTML formatted text.
- Customize the default prompt if required.
