After a while the database will grow in size and the larger it gets the slower SCM will take to load and update the UI.
You can run the ‘compact db’ operation to shrink the db and improve the loading speed of SCM.
Stop all tasks before running this operation to avoid potential errors.
Make sure no tasks are running
Click compact db
Operation may take a few minutes…
You will get a notification on completion.
