How to enable spintax for the title for AI Article Writer?
Whenever I use the rewriter/spintax feature of the software for the AI Article Writer, the title remains un-spinned. However, the rest of the article is spinned just fine. In RankerX for example, it spins the entire article plus the title in one go. This seems like a simple thing to do, but is not done? Or, am I not checking a feature in the settings? I can’t seem to figure this small thing out. Thanks.
Which spinner are you using?
I am using the built in free spinner
Ok I fixed this in next update. It should correctly spin title case words more often.
I tried it with the update and it doesn’t spin the title? Can you make it an option TO always spin the title? I am not sure why it’s set sometimes or more often. I want to bulk create spin articles or is it recommend to use paid option that will always spin the title?
Give me a sample of the title that didn’t spin.
You can try a paid spinner like word ai etc.
How to Keep Your Home Clean with Minimal Effort
The Best Daily Cleaning Habits for a Tidy Home
How to Speed Clean Your House in 30 Minutes
The Most Overlooked Areas in Your Home That Need Cleaning
How to Remove Stubborn Stains from Upholstery
The Best Way to Clean Your Home Without Harsh Chemicals
If I paste it in doc preview, I can rewrite it.
How to {Keep|Maintain|Hold} {Your Home|Your House|Your {Own|Personal} Home} {Clean|Clear} with Minimal Effort
{The Best|One Of The Best|The Most Effective} {Daily|Every Day|Day By Day} {Cleaning|Cleansing} Habits for a Tidy {Home|House|Residence}
How to {Speed|Velocity|Pace} {Clean|Clear} {Your House|Your Home|Your {Own|Personal} Home} in {30 Minutes|Half-hour}
{The Most|Probably The Most|Essentially The Most} {Overlooked|Ignored|Missed} Areas in {Your Home|Your House|Your {Own|Personal} Home} That {Need|Want} {Cleaning|Cleansing}
How to {Remove|Take Away} {Stubborn|Cussed} Stains from Upholstery
{The {Best|Greatest|Finest} Way|One Of {The Simplest|The Only|The Best} Ways|The {Easiest|Best} Way} to {Clean|Clear} {Your Home|Your House|Your {Own|Personal} Home} {Without|With Out} Harsh {Chemicals|Chemical Compounds|Chemical Substances}
So the problem isn’t the re-writer but something about settings.
Can you export the task for me so I can have a look?
Are you using custom titles?
These are not spun.
The reason is that if you are providing your own titles, rewriters can rewrite your title keywords and dilute the keyword density. Not all spinners allow you to pass in protected words either.
If you want it to be spun, you need to do it manually before pasting in the box…
I added a rewrite button to the custom titles box.
You can rewrite
Added same button to custom subheadings as well
Thank you, I will test it out and report back.
thank you, i figured it out, amazing
So the feature addition was the solution?
Yes, and I enabled rewriting.
