It possible to adjust AI Outline template so it will write a unique and expanded H1 title instead of just:
%keyword%
Also, how it is possible to make it write longer paragraphs?
AI article templates have keyword as title.
It is possible to use an AI generated title etc
Create a new template and paste in the following
<h1>%title%</h1>
<outline>
[write a long and detailed answer about %outline_heading% %keyword% in language %language% wrap each line of your response in <p> tags {and use <em> and <strong> tags on keywords|||}.
{Use bullet points or numbered list||||}]
</outline>
User macro
%title%=[one article title about %keyword%]
AI generated paragraphs are random in length you can try edit prompts to ‘write longer paragraphs’ but it may not work.
