Title case options in the Article Creator
Both titles and sub headings have force case options in the article creator.
Title case options
Sub headings case options
The default option is the case the title or sub heading was scraped in.
How to force a title case
To change the casing, you need to replace the macro with the a case macro.
The list of options for title case are:
- %title%
- %title_case%
- %title_lower_case%
- %title_sentence_case%
How to add extra text to the title
To change the case, replace the current macro with the macro of the case you require.
Example: Always make titles in lower case
Use the macro %title_lower_case%
You can use this box to fully customise the text of titles as well.
Example: Add the keyword to each title.
Create a title with the article keyword next to it.
%title_case% | About %keyword_title%
