The article creator allows you to add images to your articles using 3 sources
- Online (bing, youtube thumbnails, etc)
- AI generated images
- Images on your hard drive
You will find all settings inside content inserts > image
Find image source
Adding scraped images to your article
The first option checked by default is to look for images using Bing.
All the scraped image sources:
- Bing
- Youtube
- Creative Commons
- CC Bing
- Pexels API (enter your free pexels api)
The article creator will download 50 images per source. You can change this number by editing the download images value.
Adding AI generated images to your article
You can ask an AI model to generate images based on your keyword.
Enable the AI Image checkbox.
Click the dropdown to select which AI image service to use.
The options are:
- Dall-e
- Stable Diffusion
- SCM (in built image AI using 1000 credits per image)
You can provide API keys and edit image models inside Settings > API logins > AI image
Use the spinner to edit the number of images per article to generate.
How to add local images from your hard drive
The last option is to add images from your hard drive or another online source.
To add images from your hard drive, click on Load images
You can paste in your own online image sources as well or use the Scrape images button.
How to change the search query used to find images
Sometimes the article keyword is not descriptive enough to find images related to it.
You can change the search wording to better ind images.
Edit the image search string to do this.
By default it just uses the article %keyword%
You can type something else in…
