Generate AI images inside Article Creator AI articles
    Can insert AI images using ‘insert images’ but there is no AI macro to insert image at custom location using AI articles.
Adding a new ai [prompt]
[img-src-base64:%keyword%]
[img-src-base64: your ai image prompt]
[ ??? ] = Mark text as AI prompt.
Must start with img-src-base64: so that AI knows it has to generate an image src base64.
After the :, you can type out your prompt.
eg
[img-src-base64:dogs playing]
or use macro
Output of the AI image macro is a data:image base64 that embeds the content of the image into your article.
See example below
Example output:
