Fallback to different AI models and logins
Hi! I have membership of 1min.Ai and want to use its API with SEO content machine. Also, I have many APIs of Gemini (free Tier) which I want to use, there are total 3 versions of Gemini, in these I have to keep changing APIs to make them work.
Is it possible to change the pattern of adding API, like in settings, we click on add new API and it give option to enter API, RPM, RPD for that API, model, and other options like you already have, also change Name of API? This way, we can enter as many as API of same platform and name them as we want to remember the APIs. In Same way we can use multiple APIs of other platforms like I use megallm.io, 1min.ai, gemini, groq, and some other platform which gives free APIs.
2. Simple solution
Ability to add multiple accounts and fallback
