The current AI prompt select and creation section in the article creator is very bare bones.
Especially the user macro section has a few gotchas!
Need to know %macro%=[prompt] syntax
Each macro must be contained on one line or use \n escape
I will be redoing the user macro section.
The input will no longer require learning syntax and will instead be UI guided.
example prototype
old
VS
new prototype
old
new
The layout of still needs adjusting, but the list will allow you also to click ‘add’ ‘remove’ instead of editing the textarea directly
