It is useful to set a default system role / default prompt that is sent along with all AI instructions.
You can write prompts without having to repeat common instructions.
eg: API logins
Default system role / default prompt
Don’t repeating the prompt, don’t apologize, don’t reference yourself
All prompts you use inside SCM will have this default role / default prompt also included at the start
Now instead of
<h1>%keyword%</h1>
[write an article using the keyword "%keyword%" in %language%.
Use html tags like p, h2, h3.
{Use bullet points or numbered lists, FAQs.|} Avoid repeating my prompt and do not apologize or reference yourself.
Don't use title or meta or doctype tags.]
And always having to tell the AI to not repeat prompts, apologize or reference itself in each prompt, we let system role do it.
<h1>%keyword%</h1>
{Use bullet points or numbered lists, FAQs.|} Don't use title or meta or doctype tags.]
Just an easy time save if you have specific instructions you always send to the AI
