Bulk Scrape Images, then We Set Output HTML Link to CSV / Gsheet
I try images scraper.
Maybe we can improve by export to CSV, XLSX or gsheet.
Format output :
No | Keyword | Link Images URL 1 | Link Images URL 2 | Others
Or maybe we can use separated with | or by comma?
Also, can we add images from gmaps and google?
Or we can use custom domain like site:instagram.com keywords here
So, we will get more images, unique images.
site: instagram should work as it uses Bing search.
Image scraper only has simple copy urls,
So no csv export etc right now.
The tool is geared to saving images to hard drive, and not for scraping image urls.
But I will convert your question to a feature request.
Ya, it will be great if we have that features.
Feature export to csv, gsheet will be good.
Format output :
Thanks Tim.
Ready to test:
Find images
Select images
Default select all
Click Export image url
Select save as file
Default filename is first keyword
Output of CSV file
Just first keyword, image url
impressive. I’ll try it.
Thanks @Tim , you’re awesome :smiley:
I already try, maybe this is feedback :
I’ve tried for this keyword and finding 5 images each keyword.
  1. capital place mampang prapatan jakarta selatan
  2. centennial tower setia budi jakarta selatan
  3. the arumaya office cilandak jakarta selatan
after export, all keyword is coming from number 1st line.
Expected : using each keyword for the results.
Fixed in next update.
