Better API Settings Menu UI
Because of how much you will need to visit API Settings to change settings and enter APIs I have made it look nicer and more usable at a glance.
The old settings menu was a bit slap dash.
It listed all AI services under accordions which would open and close causing layout shifts.
So a new method, we just list services on one side and settings on the other side.
Now you can see at a glance what is connected and ready to use.
For specific to codex + claude code, we have test service buttons etc as well.
Even better, all models it can accessed is no longer hardcoded, so the list stays up to date even if the App hasn’t been.
