Ask AI - Article Creator
After adding Ask AI to dynamic scraper, I have added one to the article creator.
It will pop up a box for you to put in an ai prompt.
The window will show an warning message if you are not using openai gpt-5 model (or something better).
Although it will run with any model, you need a large LLM like gpt-5 for it to really understand how to configure the task properly.
If you have found a model that works well please let me know so that I can put it on the safe list.
Generating task…
When its done you will have a view task button
Clicking on view task
Correctly set keyword and prompt…
Correctly enabled inserts and counts
As this is a new untested feature, feedback welcome so I can decide if it works or not.
