Article spinner bug / feature suggestion
I have projects to spin articles in a directory using soft spinner. I have about 100 article in a folder. This takes a lot of time and sometimes I can’t wait the whole process to finish and I have to turn my computer off. When I restart the spinning project, using the ( >| ) icon the whole process starts from the first article doing all the articles again.So, this isn’t a pause but a complete restart.
2. Simple solution
Make the article spinner remember the already spun articles and continue the whole process until finished just like article creator does.
3. Screenshot examples
Just confirm, this is with the bulk spin translate tool yes?
I didn’t know that option existed…
I use the AI content > Article creator
Generator > Existing articles
Content sources > 0
Rewriter > Soft spin english
Translator > None
Are you doing it like this for 100 articles?
Or you have 100 keywords?
Keywords
Only one keyword (I wanted to contact you about this before too. If there are 100 keywords the spinner doesn’t stop once spins all the articles in a given folder but starts the spinning process again and again. I guess the keywords serve as a multiplier there. I don’t know if this is by design or not. I just use one keyword so the spinning project stops when all the articles in a given folder are spun.
Generator>
Existing articles (all else OFF)
Keyword acts as a multiplier.
The idea is you have 100 articles, give it 2 keywords, and you will have 200 articles.
The keyword is used to find content.
So if you had cat, dog keyword you would get images for cat and images for dog.
So if you used 100 generic articles, one folder of articles has images for cats in it and one folder of articles has images for dogs in it.
Are you just using it to spin content?
The article creator version allows you to also insert content (which bulk spin tool can’t do)
In article creator there is no mid resume when inside a keyword.
So if it fails and you have 1000 articles, it will restart from article 1000.
It might be possible to save progress so it resumes not just from last keyword, but last keyword + article count.
