@Tim - did Chat GPT get it right?
Scenario Best Tool - ChatGPT comparison
Scrape car listings, product details, real estate data
Apify
Create keyword-based blog articles for SEO SCM
Set up automated scraping pipelines with n8n/Zapier
Apify
Generate bulk content for niche websites SCM
Monitor web content updates & store in DB Apify
Quickly spin content using keyword lists
SCM
Use Apify when you need scalable data scraping, automation, and integration.
Use SCM when your main focus is creating SEO articles and content at scale.
Tim
June 8, 2025, 11:19am
2
You can do similar things with both apify and scm.
It depends on your exact workflow requirements as to which is best.
If you can provide an example we can start figuring out how to do it in SCM. Eg adding n8n
@Tim
Any thoughts on workflow for Facebook Outreach?
Tim
June 10, 2025, 5:55pm
5
Scm isnt suitable for interacting with websites like a bot it’s built to do scraping tasks primarily.
So you can use it to scrape fb contacts, but it can’t send them messages.
How It Should Work
-Scrape group members with SCM
-Feed names + group context into ChatGPT openers
-Auto-send warm DMs in Messenger via UI Vision
-Run the whole thing on autopilot with n8n
Tim
June 11, 2025, 7:08am
7
Yes the proposed steps above would work.
I’m coding n8n node now, but I am seeing how the output of n8n nodes can be used in other nodes.
This will affect how easy it is to send data from n8n SCM node to other nodes to do what you wanted.
Hey Tim, I hope all is well… How can we setup SCM to scrape fb contacts?
Tim
October 23, 2025, 12:33am
9
You would need to login first, and maybe the dynamic scraper could.
Grabbing right details you need via css
Correctly pressing right button or entering URL so that it can load and page to new results.
