- I created new variable during article creator (user macros) and tried to put in (Inserts)->(Product Info)->descriptions, but it doesn’t work
User ai macros are not global and can only be used in prompts.
However it does make a good use case to allow user macros to be available globally.
I will make this a feature request
Added to next update!
Hope now you’ll do section in SCM with all macroses to use the in any settings (variables)
Global variables are all you need ![]()
User ai macro are now global in newest update.
Let me know if it doesn’t work.
All good, can you implement window or something with all global macroses because right now need change sections to look macroses or copy them, maybe some modal window will be ok
Yes that is something I can look into adding
