- The problem
This app seems fantastic! However, I’ve noticed that it doesn’t support RTL (Right-to-
Left) writing direction in the “AI Writer” feature. When I compose a paragraph with a mixture of Arabic and English words, the text doesn’t display correctly.
Requires investigation, might need CKeditor to be used to enable proper RTL
Proper RTL support added to AI writer
To enable this, go settings > app < ui
Oh - That is great for all RTL languages
Many thanks Tim for your great support
@scm_Tim
No problems.
Because its upgraded CKeditor it also means proper inline formatting of text.
The old editor has problems editing items in the first line.
The default editor state has been cleaned up. No more dashed lines.
Empty sections now look like this
Rolling over any section shows the default hidden generate + sentence buttons as well
