Add multiple AI prompt templates to Article Creator
I want to close the gap between the AI writer and the Scraper article generator.
Specifically, to be able to transition the GSA SER template that exists only as scraped article, to the AI writer as its own template.
GSA SER template is special because it outputs
1 - Data project file
2 - Article files
Currently the AI prompt templates can only do one of these things per task!
2. Simple solution
All multiple prompts to be loaded
3. Screenshot examples
Feature complete!
Now you can add multiple prompts.
Ie create long form, short form etc all from one task.
Remove and add prompt sets as well.
Filename also support directories.
ie create files in folder pbn1 and pbn2
