Add advanced task search when using SCM API
Unable to find different tasks using SCM API without making multiple calls to api using all-projects
Also missing ability to do advanced queries with and or etc
  1. Find() api end point
  2. blog-settings end point
  3. Abort project end point
2. Simple solution
Allow passing in 2 JSON objects to execute search and also restrict what fields come back
Using same features available via a mongo.find() call
https://www.mongodb.com/docs/manual/tutorial/query-documents/
Added 2 new api end points
POST /projects/find
GET /project/abort/:id
Check api docs which have been updated
Removed some deprecated calls and renamed one api end point
Also the postman has been updated,
All possible API calls are now listed.
https://www.postman.com/maintenance-specialist-44453380/workspace/seo-content-machine/collection/25036817-6fdbc726-91fa-4a2e-bd5a-9917ef2f5100
Added /blog-settings?apikey= end point
Will return username/pwd url of all blogs managed by SCM
This must be called with an apikey, you must set one if it is blank or this call will not work.
For /blog-settings?apikey= end point
it is only get data endpoint, and what about Add, update and delete endpoint?
I can give you the same blog-settings, but if you do a POST it will update the entire object.
To create a new blog, it needs just this:
“id”:“437a-8e43-853f”
A random ID like above which you can generate anyway you can.
Would this work?
