I am getting an ECONNREFUSED on my local PC and don’t know how to fix the problem. I have restarted SEO CM several times and same error. I have updated it.
Are you running an LM on your machine @ 127.0.0.1:1234 ?
No, I have the default open ai selected.
You selected open ai #1, which is a custom service. I think you mean to select just normal open ai
OK, thank you, the other was selected already by default
Ill check the app defaults.
Thankyou
